steering pump rebuild screwed up...
Gil BullyKatz
Got my rebuild kit and I thought I put it together exactly the way I took it apart...
but I coulda sworn I heard hissing...
then smoke coming from it when I started the engine up...
the cap was mega tight and when i finally got it off...
The steering fluid was frothy!!!
AAAAARRRRGGG!!!
and maybe it was always there...
but the reservoir looks kinda cracked where it meets the fill cap...
I really screwed the pooch on this one...
Any idea what I did wrong?
Frothy means either air or water in the fluid. Jack the front end up and start the engine. Cycle the steering wheel lock to lock about a dozen times to bleed the air. It might quiet down.
Should the bleeding be done with the cap off?
Fixed...
Must've been air...
Got home from work and when I removed the cap, I noticed the level of fluid had dropped considerably...
Started it up again and turned the wheels lock to lock...
It was whining and noisy for a while until I loosened the sepentine a little bit...
Seems ok now...
I'll find out tomorrow when I drive it to buy a steering pump cooler!
Thanks for the tips!
Did you re-check the fluid level or just loosen the belt?
Both...
Since the level had dropped overnight, I had to add some more fluid.
and I'm pretty sure I had the belt too tight.
