Steering Linkage for DD with 4-5" lift
Anybody else can confirm that? I just want to make sure ES3094L and ES3096L are the same or if they are not which one connects to pitman arm and which one to driver's knuckle.
Just tie rod
Partial Conversion
1 - DS1312 - Drivers side inner tie-rod at the drag link
1 - ES3096L - Left hand thread tie-rod end (this could be either left outside or at the pitman arm - they are both the same)
1 - ES2079S - Tie Rod End Adjustment Sleeve
Drag link and tie rod
Full Conversion
1 - DS1310 - Passenger, or right side, outer tie-rod (called drag link in some applications)
1 - DS1312 - Drivers, or left side, inner tie-rod at the drag link
2 - ES3096L - Left hand thread tie-rod end (this could be either left outside or at the pitman arm - they are both the same) YOU NEED 2 OF THESE!
