So this would happen a full lock steering only? At the last 1/2" of the cycle?
http://www.ruffstuffspecialties.com/catalog/PANKIT.htmlwhere do i find the tracbar on your site? i looked but didnt see it. also on the y link setup are they supposed to go otk?
Here you go...where do i find the tracbar on your site? i looked but didnt see it. also on the y link setup are they supposed to go otk?
Those look like they would be eaten alivethe first time you flexed the rig...either when you first start to turn or when you change directions.
This is what JCR uses to eliminate the roll...
http://www.jcroffroad.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=1TNSTBSH&Category_Code=S6
Thats kind of what I thought, great for a street rig that looks pretty but gone instantly on a rig thats used...I hate them (the bushing not JCR). Another local member and I eat right through them...
I know the knuckles would have to be drilled either way, but these could be use UTK correct?
Max, you should make me one too. (=
In theory you would only want to put them on top but they are used either way from the major auto manufacturers themselves.I was under the impression that there was a difference in one of the TRE's between UTK and OTK.
I am going to have to think on this one, it was a problem I was simply not aware of...yeah, that one does. The spacer goes on the TRE on the passenger side knuckle.
I think I covered it in the last post, they are better simply because we make them that way, they are less expensive because? Because thats the kind of people we areThere are a few things that set these kits apart from the rest.
The Hex Head bungs make adjustment very easy and steering needs very fine adjustment. They are also much more expensive to make.
The Safety Misalignment eliminates a critical join while doing 2 essential jobs, most companies will not go to the expense of the much larger diameter steel required to make them.
We add these 2 items and the cost is lower, not higher, because we smply aren't that greedy
