So you're positive the Waggy pitman will work or do we need to look at custom?
Stock type pitmans are fairly cheap a group deal might not get us much, but would be worth checking into. If I dig real hard I might even be able to dig up some used drop arms. Lifted Waggy's are almost as common as totaled lifted Waggy's around here.
My issue is I had my high steer arms double drilled and the drag link had to be out that far so the tie rod behind it would clear the springs. The measurement from the center of the ball joint to the drag link hole is almost exactly the same as the Ford knuckles I was running last year.
I know it will go on the steering box, and I know it's longer, I'd guess about 1 inch. However I do suspect that the taper for the DLE may be different than the XJ pitman, but that's relatively easy to fix with a new DLE and/or a reamer.
Ok, got dirty today and measured a few pitman arms laying around my friends yard -
the XJ pitman arm is about 6.25" long (hole center to hole center) and has about 2.5" drop (again center to center)
1977 Grand Wag pitman arm is about 7.25" long and has about a 1/2" drop overall.
My drag link to attachment point to ball joint (center) measures about 7.5" for my factory 1976 Ford f-150 disc brake knuckles (5 bolts hold spindle to knuckle)
I didnt measure the waggy knuckle, and i didnt have an XJ 30 laying around to measure, but it seems that a Waggy 2" drop (2" more drop than factory) pitman arm would be the ideal candidate to regain full lock to lock steering...
incase anyone else was looking for this.
will post up with where i found one and how much $$$
I have a HP dana 44 that I receintly swaped in. Its been narrowed to waggy width. I havent noticed any steering issues with it yet but if theres more turning to be gained, I am intrested.
I have a WMS pitman with the exact same drop as a stock XJ pitman but 1/2" or 3/4" longer (don't remember which).
I'd be happy to sell it if anyone's interested.
