Usually this is an indication that the starter has a worn or otherwise "floating" brush...
... round here the starters and solenoids are most often sold together so the discussion is usually moot ,
BUT since the starter's armature provides the "ground" for the solenoid... you really can't tell which one is hosed until you seperate the electrical connection for the starter off of the solenoid, and connect it to a known good starter (or similar load - I used to use a battery load tester) listen for the solenoid's loud slammin click AND watch the load to ensure that there's a good current path!
I do understand the wanna be sure thing though - that Mitsu-gear reduction starter is a few $$ with or without the solenoid (while the solenoid is only a few $$)
