ROBERTK said:avery heres the axle I was talking about just FYI...
http://www.pirate4x4.com/forum/showthread.php?t=500369
That thing is pretty cool.
Scrappy said:BUY IT!
cracker said:I think it needs 17s, the housing needs to be swapped and I would still need a third member.
That would be a lot of $$$
Root Moose said:You guys aren't "worried" about the welded knuckle and "C"?
I dunno, can't get my head wrapped around that for some reason.
Goatman said:Has anyone run across the diameter of a 33 spline Dodge stub shaft?
Goatman said:Looks like there is about a 15% difference in strength between 33 and 35 splines, so if the better alloy shafts are 15% stronger than Spicers, my 33 spline stubs are equal strength to a 35 spline Spicer. The yokes are still stronger, which helps eliminate yoke/u-joint failure, those yokes are beefy looking.
BTW, what's the spline pitch of our 19 spline, 1.23" diameter D44 stubs?![]()
Goatman said:I'm wondering how the strength compares between my 33 spline Tera/Dutchman stub and a 35 spline Spicer. I'm thinking it should be about the same in the splines, but should be stronger in the yokes. Since I'm sticking to 37" tires for now, I'm hoping it will be pretty bullet proof...................
I just have to get used to that damn air locker.![]()
Paul S said:Just wait for Cracker to get drunk swap 'um out for his 300M stubs.
I'd be happy to help.
Paul
CRASH said:Is that front 60 you have built with Dodge unit bearings? How else did you get 33 spline stubs?
CRASH said:Why does Tera have to be so ghey?
