Devilfrog
- Duncan, BC
And some finishing touches ... got the front housing and 3-link finished, Housing trussed and fully welded, swapped rubber end on UCA to cartridge joint and gusseted the frame side mount. Big thumbs up to the guys at Karnage. Time to start saving for the fillings.
and just scheduled the diff filling session ... the axle will be stuffed with Detroit true trac, and 4.56 gears. My spare 8.25 axle with Detroit will get a new pinion seal and solid pinion spacer. Then just a few spring perches away from being ready to play. Right now she's enjoying a well deserved rest while I flog the MJ and tackle the XJ's main wiring refresh finally (thanks to 5-90 for the kit). And then it'll finally be time to tackle the exhaust from manifold to tail ... the old hodge podge is gonna go!
