Devilfrog
- Duncan, BC
So ... picked a '00 Cherokee back in '04 and it served as our Daily driver while I flogged my Bronco. Then life hit and the bronco is long gone and the Cherokee remains. Recently the wife got her new "minivan" ... an '08 JK Sahara 4dr. Deal was she got that and I can do what I want with the Cherokee. So, time to make it a little less ... pedestrian.
It's been fairly relaible and good to us over the years ... we did have a bit of a hiccup at 160,000km's when the shitty head csating of the '00's came to bear. Cracked between the 3/4 cylinder cooling jacket ... Yay. Swapped in a '93 head and SS exhaust, keeping the '00 intake and such. Worked great but getting hte exhaust sorted out was a pain, but it's worked out OK so far (getting time for a new exhaust so I'll sort that one out again.
Fast forward and we're now sitting at 270,000km's and she's still running strong with the only annoying issue being an intermittenat valve cover leak form the 93 Valve cover (will be swapping the '00 VC shortly).
And on we go with things and there was a need to replace the rear springs ... towing the tent trailer left the rear riding on the bumpstops. If I gotta replace it, might as well lift it.
So I snagged a set of '95 Dakota rear springs (lucked out and the PO had made a set of add a leaves saving me having to cut the stock dakota main). "96 dakota rear soft line for the brakes and new u-bolts and such from Island spring got it sorted. Used Comanche shocks for the rear and just did the Sway Bar BPE for now to get the rear done. Of course all four shock bolts snapped so out came the air hammer and some 10mm 10.9 bolts dropped in from the top of the shock crossmember fixed that. Total lift on the rear so far 4"
Had previously purchased a A/A SYE kit and so I finally got around to doing that bit, pretty straight forward with the hard part being getting the case out.
For the front ... Used a set of '79 Bronco 6cyl coils (270-ish lb/in rate) and they raised the front 2.5". still waiting on some 1" spacers and a few other bits to finish the front (sway links, BPE's ...). Used '92 YJ front brake lines, and will be using TJ sway links to get me going for now on the sway bar. For shocks I'm using '92 YJ fronts with BPE's.
As for tires ... in keeping with the low buck-ness of this build ... I picked up some Spidertrax wheel adapters from Westshore spring and 4X4 and threw on my Wife's stock JK Sahara wheels/tires. They are a 255/70R18 which is a 32x10.50R18 otherwise. Sure they aren't exactly aggressive (all right, barely even tame) ... but it saved me $1200 beans on new rims and tires for now and will let me decide If I like 32's or will drop down to 31's. But being as I live in Duncan and Work in Tofino (240kms once per week - going to work, and then back home the following week so 480km round trip) ... these'll do for now while I sort out the bugs. And with 32's my speedo should read somewhere close to accurate now, it's always read 10% high since we got it (although it took me a while to figure out why the cops never tagged me for speeding even though I thought I was at times)
In the books is a WJ front brake swap, WJ steering, and ZJ rear disks (if I don't find a 3.73 or 4.10 disc Explorer 8.8), Napier flares, some form of custom bumpers, and 2x6 rockers .... and of course 16" rims (steel) and some decent tires.
How it looks now
and some progress pics -
Fat Boib's tracbar bracket.
rear leaf and shock ... needs bumpstops welded on and I left the overloads in as I do tow.
Front springs and YJ brake lines, Fat Bob's Lower Arms
t-case out
took a break and tried teh hot rod look
Ye Olde SYE kit installed
Now I just need a Naxja stickum to add.
This was the only reall problem I had with the SYE kit ... have to fix that later
All in all there is nothing fancy or innovative here ... It's not meant to be a rock dominator, I got a quad for that these days ... but it is the basic medium duty wheeler and general transportation/tow rig. Still need to button up a few things once some parts arrive and then sort out the rear driveshaft. I have my front and a ZJ V8 front to choose from. The front will wait until I get around to drilling it out for u-bolts, one of the four snapped so that made that choice easy.
Should I just grind down the nub on the Speed sensor retainer? and I'm thinking of using solid axle Ford 1/2ton lower spring retainers to add a little more to the front ... they would be bolted to the stock spring mounts and act as the reatiner as well. Should add another 1.5"
I have started pulling the rear shackle bolts and the uppers came out pretty easily, I guess I got lucky since all other bolts snapped. How much shackle would I need to rotate the pinion correctly (also have some shackle relocation brackets coming from HD offroad.
Or should I just plan to do a combo of a slightly longer shackle and degree shims?
Yeah, I know the JK wheels look kinda goofy, but the wife likes them so I guess I can deal with it for now, it was a cost saving in the 'right now' ... and I already have a potential buyer for the wheels and adapters ... hopefully with the sale of my stock Icons and these I can get some proper treads on this thing.
Dave
How it looks now
t-case out
Dave
