Talyn
- Radford, Communistwealth of Virginia
Has nothing to do with the 7th injector, as stock injector still spray fuel in the port. The meth, yes.
Also why are all of the cooling passages plugged?
Yeah, thought it was drained when pulling the hoses and they were dry. It did help check for piston cracks/leaks, LOL.
Stock Victor Reinz (non MLS) head gasket. 180k on it. Held up surprisingly well all things considered. Lol.What type of gasket went? Assuming stock...
Cylinder #6 ate a sparkplug. No detonation.Having bit of pre-det there? Also why are all of the cooling passages pluged?
Wrong Jeep. Lol.#becauseracejeep!
Bought new sparkplugs from Pepboys several months ago. Was given stock heat range plugs. WHOOPS!!![]()
Survey says, pre-ignition/detonation caused the plug damage, due to lean mixture.
My Jeep is tuned rich. Didn't detonate.
Source - http://www.onestopauto.com/What-causes-spark-knock.htmlMild detonation can occur in almost any engine and will not cause damage. Prolonged heavy detonation can crack pistons and rings, blow out head gaskets, damage spark plugs and valves, and flatten rod bearings.
