You don't know me. You don't know if I work at the corner store, on the dole or won the lottery. You don't have to worry about how much I spend or what I spend it on.
I don't think he's worried how much you spent. I think it's more a matter of a kit that is advertised as plug and play out of the box, costing $4000 to the general public shouldn't require so much extra work to make it run right. Hence why he referred to you do doing Rick's work. It sounds like Rick should've had the fuel and everything else worked out so that customers could buy the kit, install it and be ready to go with maybe a little extra tuning for their specific use, not figure out how to make it all work.
It does run, but I want it to run better. I want to do that, I can do that and I will do that.
A supercharged engine not being able to enter boost is not running.
A box of parts, that's it? And that makes you an expert on the topic.
I'd imagine, if you really look at it, buying a box of parts and making it run (which IIRC he hasn't made run yet) would actually make someone more of an expert than someone buying a supposedly plug and play kit...buying the parts would require research and thought whereas the kit is a kit - the thought has already been done (except apparently with the work you guys are going through, the thought wasn't done already)...
Your definition of a lot or a little bit of money is different than mine.
What you see in a box of parts or a complete kit is different than mine.
Your idea of plug and play is different than mine.
Plug and play means precisely that, plug and play. That is the definition. You plug it in and it's ready to play.
So if you don't like or agree with someone else's thoughts or ideas, you bully them.
He points out what he sees as problems. Yes, he is blunt sometimes, but you two have decided that everything he says must be vehemently argued. Your son in particular will sit and complain about Yan's comments while being every bit as much a jerk or moreso.
He didn't seem to start going after you guys in this thread, but your insistence on being right or proving him wrong turned it from actual technical critique and advice stemming from his dislike for the kit or the guy who designed it, to just plain foolish arguing.
