- NE Texas
BDS front and rear..
just do it!
eace:
just do it!
this is what i have been uesing
http://www.naxja.org/forum/showthread.php?t=1004504&highlight=bastard+pack
Bronze
Jeep XJ total length = 51.625... are these numbers with the weight of the vehicle on them? BDS said their packs are 48.625"...?go for the 3.5" ome and use a main leaf out of something else
I've been making a chart looking at options
The dodge caravan leaves look like good candidates.
the e150 springs are looking good to me
Agreed, those look great. All we need are spring-rate's now.
Some of the dodge main-leaves had a funky oval forward bushing which might be hard to source if it goes bad. If the ford van bushings are round they may be superior to any dodge can leaf you can find. I couldn't find any dodge leaves with the round bushing so I have oval but it works fine. The bushings on my dodge van leaves were slightly large for the xj bolts but I found that a 1/2 piece of copper hard line makes a perfect sleeve/bushing with no slop.
Not worried about spring rates too Much I would only source the main from these packs and source the remaining leaves from smaller vehicles. My current plant is to remove the AAL from the OME pack I have and chop the bushings off the main then add a chopped Dakota main and one of the leaves in the chart. considering removing the overload leaf and adding one more Dakota leaf.
Sorry if you mentioned it previously but why are you changing your current pack?
It's pretty soft and my axle is farther forward than I would like. I'm also about to switch all my parts over to a different Jeep so I figure this is the easiest time to fix what I don't like.
Which one? There's like 10 bastard-pack combinations in that thread.
Ended up placing an order for some 4.5" BDS coils, and 3" BDS leaf packs (I'll be running a JKS shackle in combo with them).
I called BDS today, and they were super helpful. I was surprised to hear the rear packs are a 7 leaf pack (my old 4.5" RE's were 6). I think they should work well for me. If not, I'll be looking more into the Dodge van main leaf swap later in the year.
Like Rich said, no matter what pack I go with I'll probably end up bastardizing it anyway. I figure the BDS pack should be a good starting point. Plus they have a kick ass warranty!
