Georgia Mike
- Flowery Branch,GA
Just remember,if you drive it on the street much,I can't strees it enough......rotate-rotate-rotate! If you don't regularly rotate your tires you will almost completely wear the passenger's side tire out before the other one is half worn. And keep a close eye on tire pressures! An ideal setup is to have a 6'-7' long air hose with two clamping air chucks on either end. Clamp each end to each wheel's valve stem to equalize the pressures evenly.
