Speedo Gears - $5 each
cracker
La Mierda
I have a handful of speedo gears and from different generations.
This is what I have:
Left to Right. 39, 19?, 34, 34, 30, 28.
Here is your guide chart.
Located in Pasadena
91-93 are long shaft
94-01 are short shaft
That should help you determine if it will work in your vehicle
Put me in line for the 30..
Avery, if the other guys don't come through, I will take that speedo gear.
I pass by Pasadena everyday on my way home and can swing by (at your convenience) but, I don't want to step on anybody's toes.
Sent you a PM
Thanks,
Hans
Sent you a PM
Thanks,
Hans
Oh yeah, that's the 39 tooth
Hans
So who ever wants these please PM me and we need to arrange getting them to you and $$$ to me.
Thanks
-Avery
Why no 35 tooth gear?
Probably using it, lol.
I have some PMs I need to go through but as of right now, the 39 and the 19? are gone.
i'll take the 34!
So what is the correct speedo gear chart? I can't seem to find one that matches the one above. All the ones i've found say a 34T gear is for 38" tires and 4:56. But above says 35" and 4:56. Thanks
If the above chart is correct i'll take the other 34T
That is the Advanced Adapters gear chart.
If you already have the gears and tires you're planning on I would calculate it yourself instead of relying on a gear chart.
I did so and the speedometer in my red Jeep is accurate up to 2% or so.
