Spark Timing on a Renix 4.0
ok, got new plugs today, and removed the spark coil to clean connections.
My coil ohms test as follows..
neg. primary to highvolt terminal....4.88 k ohm
pos. primary to highvolt terminal.... 4.88 k ohm
neg to pos. primary terminals......... 1.3 ohm
neg primary to coil case.................. infinite, open.
I dont see in the factory manual what these values should be. are these values for the coil good?,
for the egr, yes it functions, I will check the egr solenoid at idle once I get the coil and wires reinstalled, and will check fuel pressure.
thanks!
