Black1990jeep
- california
on my 19904 liter Renix motor, I have hunting idle, long cranking times before she starts, and at idle she smells of fuel out the tailpipe i.e. rich. But she does seem ok when on the highway, normal power and acceleration. This started happening during my last road trip, prior to that she just passed smog test with flying colors.
Engine is a factory rebuild with only about 50K miles on it.
I read manifold vacuum ad get 5 to 10 inches which varies slowly between these two values as the idle speed wanders. thus my vacuum is low (engine warmed up,throttle closed) possible causes of low manifold vacuum are.....
1..Intake leaks....., but I performed a fairly exhaustive smoke test, and NO leaks found, prior to that I tried the flammable spray method, but with a hunting idle, that diagnostic method was not effective
2.. Retarded spark timing...
3.. Bad valve timing...
4.. Bad compression... since the vacuum reading is consistent, without rapid changes, unless all six cylinders are low compresion, this is not likely my problem, hard to imagine all six sets of rings or valve started leaking all of a sudden, no excessive blow by out the oil filler.
So now I am down to spark ,or valve timing right?
valve timing issue would be a jumped chain, but with low miles on motor that is not expected
So my next test will be to check timing
But what should the advance at idle warmed up be?. Heck I can barely see the timing marks. unlike my usual cars with vacum advance that are set to the timing mark , my jeep does the advance by the magic of the ecu, thus I dont have a specification on how to check timing.
also my dizzie clamp is correctly tightened, it is not loose and moving around, Rotor and cap are good and fairly new as are the plugwires and plugs.
So what may cause the spark timing to be wrong? and how is timing checked, what amount of advance at idle, and what is max advance at what speed? I want to check this with my timing strobe.
thanks!
thanks!
