Spare parts or tools
PacificEd
Middle Tennessee
I thought this might be a good place to post up stuff that you guys are bringing.
All of my parts are Renix based but here is a list of what I will have:
2 8.8 driveshaft flange adapters
2 front stock driveshafts
2 long D30 shaft w/HO unit bearing
1 short D30 shaft w/HO unit bearing
1 set of upper and lower radiator hoses
fluids
2 760 joints
u-bolt strap kit
upper control arm bushings
fan belt
idler pulley
plus a bunch of other little items I can't remember.
Two spare long shafts, one spare short shaft, drill, angle grinder, electric impact, bag full of tools, spare fluids, misc other crap and a spare fan clutch.
Parts wise, I won't be of much help... But the tools I carry should cover any repair needed...
I have on board air, but its not unlimited =/
I have a 10lb CO2 tank and an ARB compressor as a back up.
Parts wise I carry;
starter
alternator
drive shaft(mine is the same f/r)
stub shafts
96 fuel pump
ball joints
drag link
8.25 29 spline rear axle shaft
spare cps
There is more, thats just what I remember
I also have a CPS for a 97+, a NSS for a 97, maybe 98-01.
I'll have spare D60 front shafts. Spare hoses and belts. A spare steering box. Spare 231 TC parts, specifically an output shaft. I'll also have a spare distributor. Will have the 110 welder running flux and the small compressor. IDK what else.
I will have 30 spline dana 30 inners, many different ujoints, and several different axle yokes, and a couple different crush sleeves.
Tools...should have a good variety. I'm also a fairly big guy so I can lift heavy objects if need be.
If I can remember to grab it out of the trailer tonight I can bring mine...
mac 'have a giant list of things to pack tonight' gyvr
I didn't pack mine with the others bringing theirs.
mac 'hope no one needs one' gyvr
