Spal 14in fan in stock mech shroud
rmz45099
OC, CA
Spal fan mounted in a stock mech fan shourd.
Works great on the trail or around town. Lacks on the highway at least in my jeep. At speeds under 50 it cools well enough to close the thermostat.
Drop in install.
Need to either grind flush the fan pulley studs or pull the studs and install bolts in their place.
Less than 3000 miles on the fan.
fan sells new for 90.
Asking 50 for the fan and shroud.
Call or text at 714 three 5 zero 8 nine 1 one
1280. As I understand it spal rates their fans differently then most of the lower end company's and the cfm rating is true to spec.
