- Terra Firma
I need a pair of spring perches to weld onto a Dana 35. Mopar Performance Catalog has them but only for a 3" axle. The Dana 35 tubes are smaller. Anybody got a source for perches sized to fit the D35?
1986xj said:
Mark WNC said:Try M.O.R.E., thats where I got mine for the exploder axle.
Rawbrown said:rubicon express has there anti-wrap perches. about 30$ a set. I put them on every axle I build. they give about 1/2" of lift also...
mad maXJ said:get the perches for 3" tubes and weld them on, they'll be fine. if it's that big a deal, just spend 5 minutes with a grinder to decrease the radius.
i make all my perches out of box tube, it's cheap and easy
Beezil said:yeah, I was trying to tell him that, but the only threads of mine he pays attention to are the ones he wants to delete.
unless............
UNLESS EAGLE HAS ME ON HIS IGNORE LIST!!!!!!!!!!!!!!!
eagle???????
can you read me?
Eagle said:Can that big a gap be filled in with weld material?
BajaCherokee92 said:Are you serious? :scared:
Eagle said:Of course I'm serious. I told you -- I'm not a welder.
Eagle said:What's an ignore list?
I can't read you, Beezil, I'm too busy ignoring you.
I'm not a welder. Looks to me like at the outer ends if I use the 3" size perches from Mopar I'll have about a 1/8" gap to make up. Can that big a gap be filled in with weld material?
Beezil said:absolutly.....
you'll be fine......
if the 3" perches are the only ones you can find easily, then my all means, grab them.
the perch will touch the tube from the midpoint, and the gap will widen from a wee sliver to an eigth toward the ends, but there really is no "gap" to fill, if the welder starts at the midpoint and works toward the ends, the bead will flow against the bead, and into the minimal space. welding the backside of the previous weld will be very easy.....NO gap what-so-ever.
