some things at sunrise picknpull
blondejoncherokee
sacramento
there were 2 4cyl XJs,
one was a 99 2wd with a 8.25 rear, 410s, and probably 29 spline. not a bad rear end . next week is 50% so for around 80$ you could have 4.10s and decent strength... if the other 4cyl has 4.10s, grab the front axle and you'll have 4.10s for around 230$ or so on half off day.
other 4cyl was 4wd but I did not check the tags, both where manuals.
a lot of v8 ZJs with the 34" long front DS if anyone needs one of those.
there were a lot of blazers and the one 4cyl XJ with 26-27" long front CV 1310 Driveshafts, these might work good for a manual XJ front setup with an atlas since the front usually has to get shortened 1-2" and aren't manuals 29" to start with. I am running a 28.75" front DS with my AW4 and 2 speed atlas...
Also a WJ in the regular yard with knuckles, and 3 WJS in the premier yard with knuckles.
Also, a 27" front DS connected to a np242 t case sitting in between one of the WJs and one of the derangos in the premier yard
