cause a blown up R&P is so much better
In my opinion, yes. I have countless hours of bracket fab into my housing for the coilovers and otk steering etc. The housing is already messed up from the last break I had. If the housing gets trashed, swapping in a new housing would be a ton of work since I'd have to strip it and rebuild all the brackets and truss. Not to mention, would you rather have 2wd on a tough trail, or separate the knuckle from the inner c completely and try to get out of that "difficult" trail with only 3 wheels attached and the housing dragging through the mud and rocks? That's just the way I look at it. Also, even cost wise the ring and pinion is better than an expensive locker setup, like an ARB.
