WildernessJeep
- Houston, TX & Weston, CO
So I'm running a 98 XJ, with 31's and ARB's in both axles. I was getting silly up in the snow/mountains and thought I popped a U-joint in the long side shaft. I got it home and pulled the shaft to replace the U-joint and find this:
So I think these were the stock axles, maybe not. They are definately 27 spline (which means the locker is too).
Everything I see on the Superior website is 30 spline, and $1,000 or more. Should I just run down and get a set from a junkyard? I live in a big city and can probably pick up non-specialty parts from a local drivetrain store.
Opinions?? Are the superior "super 30" axles worth triple the cost?
Also, I can't get the broken stub out of the carrier, so thus the carrier won't come out. I thought about turning the Jeep sidways and shaking it up and down, but figured there must be an easier way.
Thanks.
Thanks.
