So Cal KARMA Thread 2009!!!!!
Status
Not open for further replies.
Hey got a big one for whoever needs a set of rubbers.
They are (4) 33x12.5x15 BFG muds
- 3 have about %50 tread, hold air, a little cracking, and alot of wheeling abuse.
- 1 has 50% left, but only holds air for a week before needs to get re-filled.
heres some pics:
http://www.naxja.org/forum/showthread.php?t=1008075
There free so never the less. First come first serve.
DAANG! i need 16in rims....
heres some pics:
PM sent if you still have them, thanks.
I'm also interested, I could definitely use these!
heres some pics:
3rd inline please.
Sorry, i know you are from here..I just felt like screwing with someone..LOL..When you coming back to CA
2nd weekend of Oct, Thanksgiving weekend, and then winter break.
I'm moving from my apartment and I have some axles available.
Low pinion dana 30 housing, no outer knuckles or shafts. I have the carrier for it but it had a busted ring and a pinion and the case might be damaged as a result of deflexion. But its
free.
Two NON C-clip dana 35 axles, complete, one's 3.73 and the other is 4.11. The 4.11 broke on me while driving to work, propably as a result of when the front 30 R&P broke. Pinion spins but shafts don't, I've never opened it up.
And a C-clip dana 35 complete, 3.55 gears.
Send me a PM if interested, I will drive to drop off it its within reason.
free.
Is it possible to convert an 8 1/4 to non c-clip using parts from a D35?
Stock doughnut spare tire with light gray carpet cover out of a '98.
Cover has a slight cut that is barely noticeable, tire looks like it has never been used.
They go in the dumpster this week...
Stock front springs.
Stock LCA.
Stock Rear Leafs.
All out of a 88 Cherokee, i think there the one that came on the rig... so the rear leafs are not the best. No Hardware.
I have a light green microfiber couch in excellent condition. I'm moving and don't have room for it.
I have it on CL for $100, but I'll give it to a fellow NAXJA member (or non-member) for free.
It has to be out of here by Wednesday morning. Come and get it.
http://orangecounty.craigslist.org/fuo/1391252519.html
Status
