I got some used stock motor mounts with some good life left in them
Thank you,
I'll take em
I'll come over later this week if possible.
Come get them.
Also, the Diff in the picture is also up for karma.
1989 ish Vac-Disco, converted to run a one piece axle. Missing trackbar bracket, sway bar brackets, blown out upper bushings, ball joints seem to be ok, late model knucles, 2000 rotors and calipers, shock mounts are on the loer control arm bracket, hole in the top where the ARB came through. there are no gears inside, just the bearing caps and a bunch of red rags.
Basically it's worn out.... Good part is that it's strait, and useable with alot of work. I drove on it for the last 9 months, just upgraded to a non disco housing.
Same thing applies as the other crap. Come get it before next Monday or it hits the can.
If he doesn't have those calipers, I have a set you can have.Hey justin do you still have the calipers? are they any good?
I've got a bunch of hose for an air compressor/air tools. The guy who gave it to me said there were no leaks and it looks like its in pretty new shape. I think there's about 50 ft of the stuff.
1998 stock steering, knuckles and calipers. come get all of it before next Monday or it hits the trash can.
also a back seat, and a gas tank.
I'd like to pick up that gas tank if it will fit a '92.also a back seat, and a gas tank.
wow, that's exactly what i have. right down to no pump and grey. wierd
