- So.Cal. Low Desert
When is the best time up there Scott?
October to... June... after June :flame:
Curt
Hey curt did you get your work done today? Do i need to come over an lend you a hand? No problem if you need some help.
i dont know to run a 4.5in long arm or a 6.5long arm!! either way its going to be rough country but a friend of mine keeps bringing up the whole center of gravity thing and not go to higher then 5in but what you guys think?
10-4 I got what I wanted to done today... MJ trailer on O.E. XJ springs (thanks Aaron II) via relocated spring hangers :shocked:... still have ALLOT to do...
Curt
Curt
Hey paul what did you do with your old shocks? The ones you had on the 4.5 lift. The wifes jeep needs new shocks all the way around. I'll buy them
thanks for the help yesterday scott... everything is working great. we got a lot done, steering is better, diff isnt leaking, fender trimming worked out better than expected.
next time:
modify rock rails
fine tune front axle (no bump stops, yay!)
bend rear flares for more clearance OR should i say BEND it back .
How does it feel Scott?
you got a welder....make one lazy ass!
