So Cal desert rats
Looks like a Yellow is Cool with All the lights and a future winch. My second battery will be a Yellow.
RedTop: Use this for normal engine starting where an alternator immediately monitors the state of charge and provides energy to the battery whenever it is needed. This would describe most stock vehicles.
  • Automotive and RV under-hood starting
  • Heavy equipment where starting is the primary function
  • Diesel powered vehicles with no aftermarket electronics
YellowTop: Use this when electrical loads are higher than average, or when the discharge cycle is more than typical engine starting, such as vehicles without alternators. This also includes vehicles with significant electrical loads that may exceed the average alternator output (for example aftermarket audio system, GPS, chargers, winch, snowplow, inverters, drag cars). This can also include vehicles that have a lot of electronics from the factory, such as a minivan with power sliding doors and a DVD player, especially if the DVD player is used when the engine isn’t running.
  • Racing vehicles without a charging system (alternator or generator)
  • Dedicated drag racing vehicles
  • Diesel powered vehicles with aftermarket electronics
  • Car audio/video applications exceeding 250 watts over the OE system
  • Vehicles or heavy equipment with inverters, hydraulics, winches or other accessories
  • Electric vehicles
BlueTop: The BlueTop starting battery (dark gray case) is to be used when a dedicated starting battery is required and it should never be used for cycling duty. The dual purpose BlueTop (light gray case) can be used for both starting and deep cycling; it is a true deep cycle battery with extremely high cranking power.
  • Trolling motors, marine applications with heavy electrical accessories and RVs should use a dual purpose BlueTop (which is both a starting and deep cycle battery)
  • Use a BlueTop starting battery for marine applications and RVs when the battery’s only function is engine starting
Note: The difference between BlueTop and YellowTop deep cycle batteries is that BlueTop batteries have both automotive (SAE) posts and threaded posts, while YellowTops (other than D31T) only have SAE posts.
If you ever get confused on the color tops just remember: if it has a dark gray case then it is a starting battery; if it has a light gray case then it is a deep cycle (dual purpose) battery.
I got My (red) Optima at Pepboys. Not a bad price. Give them a call, if You can't get there (111 in Indio), see if You can pay with a credit card on the phone. I'll go get it for You, I've got that much gas.
Chit tone, who was your mommy last week? Costco i think carrys them don't they?LOOK it up a computer..I swear i just saw a like white stuff on top of the hills by me...Maybe there's snow up berdoo canyon if it isn't closed down now..Never know with them huggers closing all the side runs
Been ten Years since Dale Earnhardt died. Damn Scott, 10 years.
Doing the same to Me here on NAXJA. Not at FB or anywhere else.
It took me almost 9 min to post, i closed and reopened but it is the same..It is getting to be more and more everyday..I'm thinking i'll go black and stay that way till they fix it..Hell i could save some money
WE GOT SNOW
SNOW RUNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN
Paul have you seen BB? Little morongo canyon should be thick with snow..
I'm doing Bob's lift on His XJ Monday. I'll take pic's. Tone's locker Tuesday, I'll definitely document the steps, and post here.
Yeah Scott, a little closer each day, what the fuch, knew it was going to happen eventually. I am going to have a Freaking Good time till then.
Tone, check craigslist I got my yellowtop new for $100.
