negative on the fresh fuel, it was on reserve when i parked it in the garage last augest, drove it around the blocks a couple weeks ago for the battery then around the block a couple times the other day, then it started supttering in first (rez. light still showing 4 blocks which means the rez. just came on which is normal) then when i would come up to stop signs it would bog out like it was having fuel problems. Took it back to the house parked it grabbed a gas can and went to fill it up, came back poured in about 3gals to the tank, drove it around rez. light went off engine running fine but still seems to be dieing out like the battery is going dead, so I go park it for the night with the battery tender on it. The next morning I drove it down to AAA to get it registered, the whole way down there it felt like the bike wasnt getting gas mind you it still had about 3gals, got it down to AAA got it registered, left the bike there, went to get a battery for it cause I still thought it was the battery, drove the bike home from AAA after we got the battery, put it in, engine running fine still but seemed like it wasnt getting gas ok so now Im like WTF M8 look in the tank and I can still see plenty of gas, so I get it running and start messing with the idle and reving the bike out trying to blow out whatever is in the line. Then after about 7 high revs the exhaust started smoking white smoke so Im thinking to myself ok cool Im getting some shit out that was clogged in a line... turned it off jumped in the pool cause by now it was 500* outside. Then I asked my woman if she wanted to go for a ride with the neighbor, well this is where the BULL SHIT starts to happen!!!! Start the bike up, start drivin down the road, bikes smokin white still not bad but just a little... but the bike is seeming not to get gas still and trying to stall out and the throttle had no damn pick up what so ever, getting up to 50mph was a struggle! So Im thinking ok were good it just needs to blow of the line more were good and keep driving to Palm Desert... smokes getting worse and worse the further we get, get to the 76 on 111 and San Lus Rey cause the Reserve light came on and Im thinking to my self what the F*** is going on now cause there was at least 2 1/2 gals in the tank! Fill up the tank, try to start it up, wouldnt do shit! Then Meagan says "look its leaking oil looking stuff out of the bottom of the exhaust!" So I check the oil level and son of a bitch! it has gas in it!!! Called a tow truck, got it home, parked it for the night. Next day which was yesterday, I started taking it apart, pulled the plastics, got the tank off, airbox/ram air off, coils, valve cover, spark plugs, fuel pressure regulater and stopped. The bike has 20k miles on it just a FYI that I probably should have said earlier. Anyway, the plugs looks like it wouldnt hurt to change them out. but then I twisted the throttle and looked in the throttle body and #2 was full of gas... so now I think I have a injector thats stuck open just dumping gas faster then it can get rid of but how the hell is it getting into the oil too? As for compression it sounds like has it... any ideas or book publishers that wanna hear my life story?
