Well, the snorkle is off with it's new owner! :thumbup:
I got the "revised" cold air set up done now. Here's the details:
My intention was simply to utilize the hole left behind in hopes of keeping some improved air flow and lower air temps. Dunno if this will have accomplished that goal, but it worked out pretty good.
I simply blocked off the square air intake at the front of the air box (behind the headlight) so seal the box. Then I cut a 3" hole in the rear of the air box just below where the filter sits when installed. Once I did that I needed to find a way to attach the flex hose from the box to the fender. Off to Home Depot I went.
Searching through the PVC fitting section had me finding some things that could have worked, but the parts were pretty thick, heavy and dimensionally just too big....... As I turned my back and faced the other side of the isle, contemplating the pieces I'd looked at....... there it was, right in front of me among the irrigation fittings!
3" Internal Coupling:
It was light weight, flexible and the perfect size for the flex tube and for the 3" hole I'd already made in the the air box. I bought 2 of 'em - one for the box, one for the inner fender. The first coupling I snapped one end into the box and pushed the flex hose on the other end. Then I put the other end of the flex hose on the 2nd coupling and pushed the coupling into the hole in the inner fender! Done!
CAI air box overall:
Coupling into the inner fender:
Coupling into the air box:
End of the fender coupling behind the vent:
Sealed air intake on the front of the box:
(Cut the square extended part off, then cut a patch piece from another air box, screwed it in place, black RTV to seal the gaps)
It's REALLY QUIET....... :yelclap: I can't hear the typical whistle of air as you crack the throttle body open off idle, and there's a nifty little air-suck sound coming from the fender....... Throttle response is notably improved over the snorkle. :thumbup:
I'm pretty pleased with how clean the install ended up looking and it all snaps together!
