- NC Sandhills
Well after suffering a long time with spent/sagged leafs on my 88, I finally swapped in a fresher set. My goal was 3" - 4", and I think I got it.
I was given a set of stock XJ 5 leaf packs in good shape... maybe factory Up-Country I am not sure. They had an odd shaped leaf in the #2 (right under the main leaf) that was almost as long as the main leaf. It was odd in that it has squared off ends, where all the other leafs had more rounded/tapered ends.
After dissasembly, I straightened out the three retainers, and sanded them down really well. I ordered up a roll of 2.5" x 0.093" PTFE (Teflon) and a pair of Rusty's full length +2" AALs. With a good scrubbing and solvent-wash, I sprayed them with several good coats of EZ-Slide graphite paint and let them dry for a few days. Once they cured, I measured & cut the Teflon liners to fit, drilled holes for the pins, then put them all together. Putting slippery leafs together is a handful. A couple helpers and some clamps is a plus.
Anyway got them installed yesterday with a set of factory MJ shackles, and am really pleased with the results. I took it to the nearest likely spot and flexed it up... very smooth and tons of travel. I just slapped a set of old 'Brand X' 10" travel (25"/15") gas-charged shox on there, and with those, I can get one wheel off the ground with the other well stuffed...at approx 1.5" of up-travel left. The packs may allow more droop than these shox allow... I still have to so work on the front susp, so will hold off on final tuning/measuring for new shox until that's set. The YJ rubber brakeline will be plenty long for any additional droop, but the factory XJ brake cables were way too short.
The axle is a XJ D44 Track-Lok... I kinda just freshened it up with new lube, pinion seal, and brake rehab. I wasn't sure if I would need to shim it any, and the plan is to swap in another 44 I have with regear & a locker, plus add raised shock mounts & maybe a truss. So consider this present setup a "mock up"
that will tide me over until regear time. At least I can 'wheel this season without worrying over that dang 35.
Here's some more pix:
Fun times!
Fun times!
