Brian Carpenter
- Vermont
johnsoninc86 said:I've been running the PORC kit with a front driveshaft for about three or four weeks now. Total cost- $210 No problems yet, just be prepared to re-use the factory snap ring on the mode hub once you get in the case. I called the guys and spoke to the mechanic at PORC and he said that wouldn't be a problem or i could take some sandpaper and grind down the one they gave us(it was too thick). I just reused the factory one though. No leaks, no noises, easier than thought install, and i did it all for about half the price of other kits and custom shafts! Im sittin on RE 4.5" and the front driveshaft is just about perfect, could be a little longer, but itll do.
Front Driveshaft off what year? There's no rust.. you must live in SoCA or is it a new piece?
Did anyone have any trouble with the speedo gear meshing up? It seems like mine spins in the hole and kicks itself out of mesh... then
no speedo.
talk about a pain in the neck!
