Slide in rear bumper tie ins
Mcmadman
michigan
I bought some brackets because my factory nut strips were nasty and on the passenger side there is an unused obstruction that is like a little black with two nuts and it not sure what it was used for I tried chiseling it from the bottom with no avail has anyone removed this
I am not sure what it is you are describing, but if on the passenger side it is likely an exhaust hanger of some sort.
Lrxwyce
I just got it out with a pickle fork! Took a small piece of the frame with it
I too am making bumper tie ins, using 2 x 3 steel square tube, and 1 x 2 channel. Nuts strip is 1/2 inch thick bar, drilled and tapped.
I will need to knock out the exhaust hanger tab on right side to get it all to sit flat in the frame. May perhaps drill out the welds holding it.
I will get back to that after I finish my first round of front fender trim. Priorities shifting, dont want my new tires cut up on a fender lip.
