SKOL me on tig welders
rockwerks
basics of the units
what amperage welds what thicknesses
inverter?
many also have arc/plasma cutter/tig configurations any good?
110/220? many have dual electric applicatinos?
I bought the Lincoln 185,it will weld up to 3/16" steel.It does also serve as a "stick" welder.
Okie Terry said:
Here is the ultimate in budget TIG welding.
Believe it or not, this little bugger is hot.
cyberweld_1862_1750023
It doesnt indicate any control (foot/hand) over the amperage,thats part of the "key" element of good TIG welds.
Because there is no "on the fly" adjustment.
But, like I said, it's an awsome budget TIG welder.
Hot is right. With out liquid cooling, don't expect the stinger cables to last very long at higher duty cycles.
I have one of the multi voltage Miller units we use for some off site stuff. They are great portable units. I have to run a chiller...
Lift Arc can be pretty cool, or a pain in the ass. My eyes prefer having HF. :D
BrettM said:
I wouldn't get a TIG that couldn't do Al.
Niether would I, but my requirements are different than a hobbyist.
It's worth noting that I used to commonly weld Al with DC postitive, and un-balanced HF in alot of situations. It very common in aerospace work, and primarily used when features are running close to minimums for the proper bead on thicker material. Arc, puddle and shrinkage control is excellent. Re-flowing inside corners is another great application.
--ron
All i know is we have two miller syncrowaves at work, one from the 70's thats hooked up to the chiller (this one gets used the most) and one thats like 5 years old that hardly ever gets used syncrowave 350 that we just hook up to a garden hose and run the water line out a window or door. Both of them can push 350 amps on i want to say something crazy like 95% duty cycle. To weld 1/2 inch your going to need some serious amperage, i would say atleast 200 for good penetration and with that kind of power a water cooled torch will be your best friend. The strange sounding thing is, if you plan on welding aluminum your actually going to need MORE power because it acts like a heat sink especially on bigger pieces.
