Simple rear bump stops on top of the Ubolt plates
I did the very same thing over a year ago only I stacked a few 1 inch square pieces and welded them together - no additional rubber added. Its held up fine after 4 trips to Moab and some serious flexing. I'm using the stock u-bolts as well.
I would guess that they hit the stock rubber upper bumps? Should be fine.
I had pucks in the front, worked just fine.
they are not hard rubber at all.
hockey pucks are vulcanized. they are damn hard.
Not sure how a hockey puck can deteriorate. Even with large force being put onto it, they should not simply just break down.
they wont deteriorate exactly... but ive had them crack in 2 around the bolt hold. as far as withstanding the elememts, they should last much longer than the OE bump they are going to be mating with.
Stock upper mount.
the problem with them how he has them vs what you have is that the 2 sides of the pucks are unsupported. when they are in the front (how I used to run them) they are fully supported by the coil bucket so you are just trying to compress them, they will last quite a while like that.
on what scale? I can slice one in half with a pocket knife.
sure, they are hard if you are eating them, but not if you are talking about jeep parts
the oe bumps are able to take much more deflection than a puck before tearing. without any support under them, they will crack on the sides.
but like he said, they only cost a dollar... so whatever.
I just beat the crap out of these stops with a fully loaded jeep for 200 miles through the Mojave, and they held up, although the results may have to be thrown out as I discovered that the shackles were acting as partial stops against the bumper, too.
