signal flasher not flickering
dellstopjeep
KUNA, ID
my signal flashers on each side stick. they quit flickering they just turn on. i replaced the flasher convinced that was the problem but its not.
any ideas?
What year and how many flashers? Earlier years had a flasher for the blinkers and a flasher for the hazards...later models may have had Chryco's combination flasher. If yours has two and you only replaced one, replace the other one first. A bad flasher would be my first guess.
If you replaced the combo flasher or both flashers, check the bulbs. If they all seem to light up, replace them all and see what happens.
its a 90. i used to have an 89 and my flashers went out and it was the signal flasher and its in the same spot so im pretty sure its that one
I have a 90 also, and mine is doing the same thing right now..the turn arrow on the instrument cluster comes on and stays lit, all of the blinker bulbs come on and stay lit, and there is no clicking noise when the blinker is on.
