Sierra "Karma" thread
I have one set of (6) stock, fuel injectors, renix era. They work fine, are dirty as I doubt they have ever been changed. O-rings feel decent, but probably good to replace them with new ones. I live near the Ocean Dunes. Pick up always preferred, but can ship them (on your dime) or can help arrange parts train.
Injectors are gone.
I removed my stock roof rack in it's entirety off of my sport. All black. Located in Oakland. I also removed my radio antenna, base and wire if anybody needs to replace a bent/broken one.
You have a PM.
does anyone have a set of D30 shafts they dont need? I need the ones that are non disconnect. i have the vacuum disconnect ones right now and i want to swap them so i can put the outer seal on it.
thanks.
does anyone have a set of D30 shafts they dont need? I need the ones that are non disconnect. i have the vacuum disconnect ones right now and i want to swap them so i can put the outer seal on it. thanks.
i have a set.
i could use a spare front driveshaft if you have one.
also looking for a set of 15 x 8 crager soft 8 wheels.
I have a rear driveshaft but not a front.
well let me know if you can part with them and i can keep an eye out on a front shaft for you.
thanks.
Flyingbrick I beleive needs some disco shafts.
hey Josh i will take that cleaner kit...if you still have it bring it to the toys run?.........
I still have 2001 stock injectors
A high pinion d30, 3.55
Stock xj tcase output shaft, 97+
Stock crossmember, tcase skid
Sounds good. The tcase skid is stock, but it is cut and modified to sit flush with the crossmember. Want it?
No thanks. I have a warn t-case skid. My cross member just took a beating on the pass side, where my skid does not cover.
Will you be heading down that way before thanks giving? I can use my sister as a parts train. LOL
Josh
Haha yeah no prob. I'll bring it down Friday or something. I need to go for a drive. It's been school, work, school, work.... I need to go for a nice cruise.
I'm only 30 min from fortuna.
Are you going to be going to the Toy drive Sat? If so I'll take that t-case skid or find a way to get it from you?
Dana 30 hubs and one outer shaft
