Larrythedog
- Covina CA
Air intake and filter.
wouldn't loom been cheaper than all the wire ties![]()
hell no I got 1000 of them for 4.99At least its not electrical tape.
I'm digging the brace for the filter, this has been a great build to watch. Thanks for keeping up with it, it's really coming out great. :thumbup:
The terminal strips I bought at Home Depot. Nothing fancy. I made the buss strip. Just bought some 1" X .125" copper stripes from McMaster carr, then machined them up.
Man I just found this post.I have to say 20 years ago I was fabricating a ton of VW based cars for Score,Micky Tompsons,and NDRA cars.This is some of the best home Fab work I have ever seen.You seem to know exactly were to add the beef in all the right places.My hats off to you man on the great work.I can't wait to see your jeep in action.I would have still been in Cal.If I had take'n the job I was offered at Cal Wells racing,and Toyota racing team back then.Man I miss this sh-t so bad.Keep up the good work,and the pictures.Thanks Rod
Couple of questions:
Why the internal fuel pumps? Not knocking it,(actually like the install,..)but won't that make it hard to service the pumps?
Do you have some kind of splash guard or seal between the filler neck and the window cover panel? If not, you might want to consider at least a foam or rubber gasket. Any Fuel spilling out of a fill can or coming back out of the fill neck from an over-fill is going to spill right down inside the truck.
Not sure if there's anything you can do about it, or if it's even an issue, but the closed off window panel makes it hard for the fuel man to see when the gas starts filling up in the filler neck. He won't know when the tank's full.
