JeepFreak21
- Cameron Park, CA
I was hoping for double sheer, but I'm not sure that that would stick out far enough either. It's a thought though!
Thanks!
Billy
I had the same problem. I ended up just using a grade 8 bolt and welding it below the coil pad.
I also wanted it double sheer, but it was how the TnT kit originally came, and I dont think I will put enough stress on that bolt to break it.
edit: Nevermind, I see your coil bucket is farther forward. Side note, looks like your trackbar mount might hit your coil. Does it?
i was wondering this as well, im thinking it would be something similar to mounting limit straps to the actual arm. i think it would increase the load put on the shock. think of holding a hammer horizontal with your hand close to the head, and then again at the end of the handle.What are the draw backs to mounting the shock to the control arm?
Thanks,
Billy
i think you would want the shock as close to the axle as possible, but i could be completely wrong![]()
1/8'' for a washer.How far out from the point the bolt is welded does the shock mount though?
Thanks,
Billy
Even if the shock is centered, since you are using flex joints on both sides of the arm, the arm will flop to one side or another on compression.And if it the shock isn't centered perfectly over the control arm (and even if it is maybe), won't it try to spin the arm, possibly putting stress on the bolt and bushing and stuff? :dunno:
Billy
Does anybody know the width of the lower heim on a 7100 as if you were looking straight through the mounting hole? I'm going rummaging in the steel remnants tomorrow.
Thanks!
Billy
I called Bilstein on this. Just for future reference, the widest part of the heim is 26mm or 1.023 inches.
Billy
Billy, if you're looking at a 7100 heim through the bolt hole the body is about 1.25"s wide.
