2001XJ
- Canton, MI
Guys,
Did a search but didn't quite find what I was looking for.....also might have been a little lazy since I only felt like looking through 4 pages of threads. Anyway, I have an RE lift and the driver's side is sagging a bit more than the pass. side. (almost 3/4") I was thinking of simply adding an extended shackle on that side to even it out. Any problem in doing that? I already have the RE 1.25" extended shackles on it now so does anyone know a manufacturer who makes a 1.75" or even a 2" shackle that is good quality(in the future I will be mounting a spare tire so if it makes it a little higher it will probably even back out when the spare is mounted on that side)? One more thing, I can't remember but I thought I read somewhere that the cherokee derives most of it's power from the driver's side which cause spring-wrap and can cause springs to sag on that side since that is the main power output side, is this true?
thanks
thanks
