Setting up gears?
Cox89XJ
TN
When you pay someone to setup your gears. What does it consist of? Do they disassemble and do they include gear oil ect. in the price? Also whats the going price per axle?
Your Jeep should be ready to roll when they're done, everything torqued, lubed, sealed, etc. Generally you get new ring and pinion, ring bolts, pinion bearings, carrier bearings, shims, crush washer, gear oil and pinion nut with a gear install. If you want new axle bearings or seals, you'll have to specify that.
Dont forget about proper break in and I always change the diff fluid after just a few hundred miles so I can check for metal and also to get rid of the break in oil.
price depends on your location. Around here its between 200-250 per axle.
You should include thats 200-250 per axle for *labor*. Figure ballpark $300 per axle for parts as well, plus markup.
Very true. Thank you.
