langer1
- Mineral City,Ohio
Do don't know where your brakes are?
Zice said:Yea dont put it in your oil more than like 20 miles before your oil change... it cleans your engine out and all the stuff it cleans sits in your engines oil so you want to add, run, change oil...
Happy to be able to help out a Veteran Member![]()
Big Red said:I'm so worried about putting any liquids where my air intake is. I hydro locked a motor already and it really sucks.
88XJSport said:You cannot hydrolock the engine with seafoam. Remember water doesnt compress...but seafoam, a thin oil, does![]()
Zice said:Happy to be able to help out a Veteran Member![]()
Lawn Cher' said::roflmao: :roflmao: :roflmao: :roflmao: :roflmao: :roflmao:
SCW said:I really don't think this has anything to do with hydro-locking. You can even spray a little water down the TB and cause the temps in the combustion chamber to climb, burning off a lot of crap. Water injection is somewhat common especially in military vehicles, but it doesn't mean you drown the engine in water and lock it up.
jeepnuts311 said:i have heard that this stuff was hell on oil seals and gaskets, basically with the oil leaks that old jeeps see (mine included) it may make the leaks worse. either by being harsh on the old gaskets or removing junk that may actually be plugging leaks.
any truth to this?
-Tim
99XJSPORT06 said:Switching to a Synthetic oil after a while will have the same result. I switched to synthetic on mine when it had 67K on it and with in 500 miles had an oil pan and rear main leak. Small leaks, but leaks none the less.
Back to the topic, I can just add an entire can to a tank of gas and it will clean up the crap in the fuel system correct? I'm a little leary about adding it to the engine oil or vac. line.
One can of seafoam (1pt) treats 8 to 25 gallons of gas...99XJSPORT06 said:Back to the topic, I can just add an entire can to a tank of gas and it will clean up the crap in the fuel system correct? I'm a little leary about adding it to the engine oil or vac. line.
