Seafoam
Bob is the oil guy is full of shit. Can you verify that anything in a single one of those tests is actually what he says it is? What about the speeds at which he spins the gears, he could be spinning it at 50rpm or 5000rpm. In an age of video's and youtube, he has badly shot still images. With the number of people nation wide who use the stuff with great results VS what comes down to one internet blog...
ive seen other displays that prove that lucas is good stuff... as for seafoam... i dont like it. like was said before, everything thats broken loose has to go some where. if its in your intake it breaks stuff loose in the intake and on the pistons and off the valves. if any of this gets stuck under a valve is can cause a spot to be burned into the valve and it will no longer seal. if in the oil and it breaks stuff up and it is after the filter it can get into your bearings just my opinion
You can make the same argument about anything you see on or off the Internet. Unless you do it yourself, there's no way you can be absolutely certain that what you're seeing is completely accurate and truthful. This is a dumb argument.
And yes, all of the people using it nationwide don't count for much because they don't do any kind of empirical testing and they wouldn't know what to look for if they tried. Besides "great results" are usually the placebo effect. It's what most of the additive industry survives on.
after reading what you said about him, i'd expect you to provide some proof, or at least a SLIGHT explanation.... can you disprove anything he actually says? the burden of proof is on you now.
i put very little weight behind the oil guy, but please, do share... =)
