what do you think, as many of you know I have a couple tires that have screwed up beads, what do you think of putting tubes in the tires and mount them on a standard wheel? ie: non beadlock wheel
Would this be a off road only tire? If its offroad only I would go for it.
I wouldnt run it on the highway because of the heat build up going that fast, and then if it blows going that fast.....well I hope you have a guardian angle:angel:
I tried it and had no luck. I tore one valve stem out and another just didn't hold air, I used talcum powder and everything, I finally gave up and bought MTRs no problems since
Same here. I booted a badly cut tire and tried running it with a tube. It worked fine on the highway, all tires used to have tubes, but it was a problem off road due to the low air pressure. The tire would rotate slightly causing a problem for the stem, and the tube would pinch and get small leaks. I finally pulled it out and ran the booted tire tubeless which worked fine.
