Haha I like that. Someone told me that I could get the same amount of lift if I do the bastard pack for cheaper and it rides pretty good but what do you think?
There are litterally hundreds of ways of building an XJ. If you come to NW Fest you will see ALOT of Jeeps and none of them are a like.
Personally I would WAIT on a lift. Use what you have for a while, talk to all of us on the trail, research on line till you didn't think there was anything else to learn. Then start a plan.
Most of us would recommend something along the lines of this:
Protection First
Lift
Gears/lockers
Tires
The problem with the lift is that it drives all sorts of other expensive things (SYE, Gears, Lockers, tires, wheels, brakes, etc).
If you start with a budget boost or 3" lift you can avoid MOST of the expensive stuff and piece the rest of it together over time.
Along these lines:
3" lift and 31" tires on stock rims.
Then in time you can get all of your protection 1 at a time.
Rock sliders, Gas tank, Tranfer case, engine, diffs, etc, etc.
Then work on better brakes, SYE, new wheels (to fit larger tires), longer brake lines, etc.
Then when you have the coin for gears and lockers you can do them.
Then you move into the larger tires and larger lift.
You get the idea.
baby steps. You will learn much more along the way and appreciate the journey and your pocket book will appreciate the pace.
Michael
