Rubicon Express Track Bar 9/16 bushing.
Jroemer98
Arizona
My track bar mount is wallowed out and im planning on replacing the bolt with the clayton 9/16 trackbar bolt kit. Im currently running a Rubicon Express adjustable track bar for 3.5in lift(RE1600).
My question is if anyone knows a bushing kit that will work on the RE trackbar and has a 9/16 ID sleeve, I cant seem to find anything on the internet about it.
Thank you.
Thank you.
Kevins Off Road might have something that would work. Not sure if they sell the individual pieces. Also, the super hard bushings are out of stock, but you can get them with softer ones. Maybe call them for more info?
https://kevinsoffroad.com/collectio...bar-bushings-plus-upgraded-track-bar-hardware
https://rubiconexpress.com/Suspension/Bushings-Cold-Cut-End-Rings.aspx?t_c=1&t_s=20&t_pt=10107
Not sure if its the large or small style. Worst case order both RE3704 and RE3786 and return the one that doesn't fit. What's the diameter of the hole in your TB?
Those are the wrong parts, this is what RE has. If you need to go 9/16" you just need a different inner sleeve for the RE's!
https://rubiconexpress.com/Suspension/Track-Bar-Bushings.aspx?t_c=1&t_s=20&t_pt=4124
