Begster
- Cape Cod/Boston, Mass
I have a set of RE drop brackets with braces, with a full set of RE arms.
The drop brackets have all the pieces, but no hardware is included. Brackets have a bit of rash on them, one of the brackets has a small bend on the bottom edge that does not affect performance.
Adjustable RE lower arms. Will need rubber bushings. Superflex joints are good, have never once heard any clunking or noise from them. One of them has the little set screw halfway drilled out because the allen key had stripped inside it. Arms have some rockrash but are not bent or dented.
RE fixed upper arms that were made adjustable. I took fixed arms, chopped the bushing off, and then welded a piece of threaded rod from RE's builders section in the tube. I then took the bushing eye and welded the female threaded portion to the busing. These arms were modified in early 2008 and I've not had a single issue with them.
I can also include a set of RE fixed lower arms. One of them has a bolt shank seized into the ball.
PM me, that would be the quickest way I will respond. Open to offers right now.
Not looking to ship, they are heavy and I don't feel like making trips the the post office only to have the person back out.
1st person with cash gets them.
