RS9000 Mounting Q's??
Ted Z
Michigan
Ok, my post got lost in the latest "fix" of the forums....
Can i mount RS9000's upside down?
And also does the angle of the shock in relation to the axle tube matter much?
I made a new upper mount between the frame rails and the shocks mount about 3-4 inches apart on the upper end to try to get all my travel available..
the shocks will be about 1/2 as effective at 45 than 90 degrees.
dont you run an exhaust? :eek:
They seem to be doi their job pretty good at that position... i'm gonna leave them that way 4 now....
My exhaust is a 45 turndown after the flowmaster muffler...it turns down right in front of the rear tires....
The Rancho's -- NO
The Pro Comps -- Yes
I thought the rs9000s could be mounted upside down with no ill effects
