WraithKWK
- Spring Valley, Ca.
Thanks for the tip, that's the part Im missing.
I went to install the lift yesterday and as I'm setting everything out I noticed I'm missing 2 X-flex joints.
One Upper and one Lower!
Let the Fun begin.
I called up RC and the guy was extremely polite, took my information and said they would call me on Monday to get the parts sent out.
Decided to install the cross-member
First the Trans mount did not fit, so I picked up a 4 cylinder version to get this moving.
Then the Exhaust mount just before the Cat was hitting, so I pulled that out.
I installed the 2 center bolts on each side of the Cross-Member, and when I went to install the side plates I had issues with buggered factory anchor nuts as well as one hole in the cross member was slightly off.
I'm running out to pick up a tap set to clean the threads and then I'll clearance the one hole that was a little off.
I think by the time I finish this install we should take pictures and write a "how to" for anyone else who buys this kit.
For me the Passenger side of the CM Both Front and Rear holes needed to be opened up with a half inch drill bit. Then I had to open up the holes on the passenger CM side plate as well.
The Tap I used for the Frame Anchor nuts was a 10mm x 1.25 Tap
The Transmission mount I used was
Centered: $19.99 89 Cherokee 4wd 4 Cylinder
http://www.autozone.com/autozone/parts/Duralast-Transmission-Mount/1989-Jeep-Cherokee-4WD/_/N-iuad5Z6o23q?itemIdentifier=4816_0_0_9202
The stock tranny mount on my Jeep was
Offset: $31.99 89 Cherokee 4wd 6 Cylinder
http://www.autozone.com/autozone/parts/Duralast-Transmission-Mount/1989-Jeep-Cherokee-4WD/_/N-iuad5Z6o23q?itemIdentifier=4844_0_0_26700
Before you install it, check the track bar heim and make sure that it's the teflon-lined version.
Im confused on the bushings where the upper arms mount to the axle. There are 4many bushings that look like they would fit but the center hole looks like it would need a sleeve. Any tips on removing the stock bushings.
My front TC yoke is hitting my cross-member.
