Roll Out Times, Tech Inspections & Vehicle Information
RCman
USA
Please plan on being at the park by no later than 8:30am. This gives everyone ample time to unload, air down, pack up, get inspected, pay at the park, whatever and get staged so we can roll out for 9:15am.
Also as before, there will be vehicle inspections. Typical vehicle required equipment applies (see the safety checklist and the bylaws for any questions). Please come find one of the NAC BOD (myself, Chris, and/or Travis) and we will help you get signed in and pointed to whomever is doing the inspections at that time. Then you can head off to pay the park fees.
Please remember to bring a filled out waiver form and safety checklist. This will help tremendously to speed things up. We WILL be checking to make sure you vehicle isn't hacked together (more than it needs to be ) and that you have the proper equipment (ie; in reach fire extinguisher, 1st aid kit, jack, tow points, etc). You should be able to get the 1st aid kit in a "reasonable amount of time". Use common sense here, if you have to move a spare tire, seat, and a toolbox, it probably isn't reasonable. The words "readily available" are so the fire extinguishers were not put under things like the back seat or tires/toolboxes. Obviously if it takes a minute to grab a 1st aid kit that's probably fine, if it takes that amount of time to grab a fire extinguisher it could be very well to late. Thankfully the only issue we had last year was solved quickly because the person mounted the extinguisher within reach of a strapped in driver; this is the ideal mounting if possible.
Thanks and see you all in a few months!
