roll cage?
sWissfoo
il
im going to build a roll cage, but i want to know whats the best way to put one in? 97 xj, the jeep is stripped so i have all the room i just dont know where to weld it down to?
<a href=
Just don't get in a hurry, expect 4-6 weeks easy. Good product though.
i work at machine shop so i can get dom cheap and i have welder, plus i want to be able to say i created, i just need some help in where to weld it....
My cage from JCR goes through the floor at the A and B pillars, and also in the cargo area by the hatch. The tubes are welded to "perches" that are attached to the framerails. I can take pics tomorrow morning if you like.
Either to plates on the floor or sleeve the frame rails and weld it to that.
I welded my cage to 3 X 3 angle iron, I cut the floor so one of the sides went down along the frame. I then tied that into the frame stiffiners I made.
For the rear, I cut out the top of the shackle box and tied the cage into the shackle bolts.
I boxed my shackel boxes though.
I had to get creative for the front, I dont have pict of that.
I hope this helps...
Here's mine, done by JCR:
A Pillar -
B Pillar -
Cargo Area -
Frame tie-ins -
Hope that helps. If yours turns out good, I may be heading your way when I get the 01 ready for a cage!
Damn thats rusty!
or the south.
when it comes to welding to the unibody, do i have to do it in short beads or can i lay long in hopin that i dont melt through the floor? oh ya thanks for the pics
87manche said:
doesn't MI use that crazy liquid stuff.
we still use good old rust causing salt here in OH.
That cage has lived in Indiana, which uses good old salt/molasses mix.
I should have painted those perches, but out of sight out of mind.
monkeyevil said:
Things can rust a lot in 4 years :rof:
How much you looking for to do a nice XJ cage?
You can PM me if you don't want to post it.
Very short beads, the uni will burn through faster than you think,
Practice with sheet metal and 1/4 plate or something first.
Spent most of your burn time on the heavy and carry the bead to the uni, than quickly return.
It will take a lot of practice!
