TrailHunter said:
I'm concerned about the bpilar not meeting the top in a node. If it goes on it's roof it might colapse the outter sides of the the roof where it connects to the b-pilar.
Good advice.
This is critical, as the vertical B-pillar strut as installed will not hold up the halo in a roof impact. It is more likely to bend or punch through the back of the halo. The halo bar between the pillar and halo edge will work more like a hinge, considering the leverage distance you have provided between the halo edge and the B-pillar connection. You have designed-in a tube prone to fail (the rear bar of the halo & b-pillar) during an impact because the point load on the B-pillar places the halo bar in bending and isolates the load on the single B-pillar (rather than sharing the load between both B-pillars and front/read down-bars).
(Best) Redesign the B-pillar to attach at a node vertically under the halo side bars. Use 1.75/.120 wall or larger tube for the B-pillar. A diagional or x-brace in the B-pillar will add considerable torsional resistance.
(lessor fix) Add a brace to tie-in the B-pillar to the outer edge of the halo, like your halo corner brace, but to brace the B-pillar vertically with the halo (better than what you have). A roof impact will yhen bend the B-pillar rather than the halo, unless you add a horizontal B-pillar cross bar between the bottom node of the two braces (to make any impact transfer and share the load between the two B-pillars). Making the B-pillar corner of these braces the top node of an X-brace in the B-pillar will gain back the strength lost compared to the "best" design, but with a lot more weight.
A little help from SCORE International:
As of January 1, 2006 replace rules in the Score International 2003-2006 Off-Road racing Rules and Regulations page number 29 (Vehicle Safety Equipment) through page 32.
VEHICLE SAFETY EQUIPMENT
CR33 ROLL CAGES
All vehicles in competition except Motorcycles and ATV’s must be equipped with a roll cage. Minimum design and tubing size based on seamless 4130 chromoly tubing or ASTM 1018/1026 CDS/DOM. No aluminum or other non-ferrous material permitted.
Material
Material for roll cage construction must be 4130 chromoly tubing or ASTM 1018/1026 CDS/DOM
All welding must be of the highest quality with full penetration and no undercutting of the parent metal. All welds shall conform to the American Welding Society D1.1, Structural Welding Code, Chapter 10, Tubular Structures and Standards for the material used (see AWS.Org). It is strongly recommended that the welder inspect all welds using Magnaflux™, die-penitent, or other effective methods.
All tubes must be welded 360-degrees around the circumference of the tube.
No oxy-acetylene brazing or welding allowed. Good external appearance of a weld does not necessarily guarantee its quality; poor looking welds are never a sign of good workmanship.
None of the tubing may show any signs of crimping or wall failure. All bends must be mandrel type. The center radius of the bends may not be less than three (3) times the outside diameter of the roll cage tubing.
It must be emphasized that the use of heat-treated or high carbon steels may cause problems and that bad fabrication may result in a decrease in strength (caused by brittle heat-affected zones), inadequate ductility and internal stress.
Roll Cage Tubing Sizes
For the purposes of determining roll bar tubing sizes, vehicle weight is as raced, but without fuel and driver. Note: There is an allowance of minus 0.010 inches on all tubing thicknesses. Minimum tubing size for the roll cage is:
Up to 2000 lbs.
1.500” x 0.095” CDN/4130/Seamless or ASTM 1018/1026 CDS/DOM
2001 - 2500 lbs.
1.500” x 0.120” CDN/4130/Seamless or ASTM 1018/1026 CDS/DOM
2501 - 3000 lbs.
1.750” x 0.095” CDN/4130/Seamless or ASTM 1018/1026 CDS/DOM
3001 - 4000 lbs.
1.750” x .120” CDN/4130/Seamless or ASTM 1018/1026 CDS/DOM
Over 4000 lbs.
2.000” x 0.120” CDN/4130/Seamless or ASTM 1018/1026 CDS/DOM
Construction Procedures
Cages must be securely mounted to the frame or body and gusseted and braced at all points of intersection. Cab or body mounted cages must not be attached to the body structure by direct welding, but must be bolted through and attached by the use of doubler plates (one on either side) with a minimum thickness of .187”, see Figure 4. Where bolt and nuts are used the bolts shall be at least .375” diameter SAE Grade 8 or equivalent. Roll cage terminal ends must be located to a frame or body structure that will support maximum impact and not shear.
Minimum material dimension requirements for roll cages apply to the following members of the roll cage:
(1) Front and rear hoop
(2) Front and rear interconnecting bars
(3) Rear down braces
(4) Lateral bracing
(5) Elbow and door bars
(6) Lower A-pillar tubes, and lower B-pillar tubes
Roll Cage Design
All roll cages must be constructed with at least one (1) front hoop (top of cage to floor), one (1) rear hoop(top of cage to floor), two (2) interconnecting top bars, two (2) rear down braces and one (1) diagonal brace and necessary gussets, see Figure 1. If front and/or rear hoop terminate at elbow/door bar, lower A-pillar and/or B-pillar must be made of same tubing size as roll cage. Centerlines of all required tubes must converge at intersections.
Any vehicle that is not provided with stock steel doors for its driver and co-driver must be equipped with sidebars, at least one on each side that will protect the occupants from the side. These bars must be parallel to the ground (or as close to parallel as is practical) and be located vertically in relation to the occupants to provide maximum protection without causing undue difficulty in entering or exiting the vehicle. The sidebars must be formed of tubing of the same material and dimensions as the roll cage itself and must be securely attached to the cage’s front and rear members. Additional side tubes may be required to limit cockpit intrusion, these additional tubes must be of the same size tubing as the roll cage. Tubes must be placed in such a manner as to limit openings adjacent to the occupants. Maximum opening size in this area is limited to 370 square inches.
All roll cage bars must be at least 3” in any direction from the driver and co-driver’s helmets while they are in their normal driving positions.
Gussets must be installed at all main intersections on the main cage including diagonal and rear down braces, and where single weld fractures can affect driver’s safety. Gussets may be constructed of .125” X 3” X 3” flat plate, split, formed and welded corner tubing, or tubing gussets the same thickness as the main cage material, see Figure 2 and Figure 3. Rear down braces and diagonal braces must angle no less than 30 degrees from vertical.
An inspection hole of at least .187” diameter must be drilled in a non-critical area of the roll bar hoop to facilitate verification of wall thickness. It is the prerogative of SCORE to drill a second hole if deemed necessary.
Any cage or chassis that has been built after January 1, 2006 must be identified by means of an identification plate affixed to it by the manufacturer; this identification plate must be neither copied nor moved (i.e. embedded, engraved or self destroying sticker). The identification plate must bear the name of the manufacturer, a serial number, and the date of manufacturer.
Head/neck restraints designed to prevent whiplash are required on all vehicles. These restraints must be a headrest of approximately 36 square inches, with a resilient padding at least 2” thick. Any portion of the roll bar or bracing which might come in contact with the helmet must be padded.
Roll Cage and Vehicle Annual Inspection
All vehicles must have their cages approved prior to racing in a score event. The inspection will be preformed at the Score Technical office. After passing inspection and paying Inspection fees all vehicles will receive a Score I.D. tag that is to remain with the vehicle at all times. If tag is removed or lost vehicle must be re-inspected and retagged. Any modification to an approved cage may render its approval invalid, and may need to be re-approved. All repairs to a roll cage damaged after an accident must be re-approved by SCORE International.
All vehicles built before January 1, 2006 may be required to have an inspection every six months.
HTH?
