1ABrian
- New Hampshire
man this is one MAD build!! Love it
Bet ya didnt know these jeeps run pritty decent on e85. Aside from taking longer to start and not Having alot of power at full throttle. Everyday driving is just fine, i dont see any less mpg and its around 40 cents cheaper, and much cleaner. I think i have around 4000 miles on it running it no probs. o would like to get a programmer and custom tunning to make it run at its full potential i think it needs to run richer an more timing.
e85 is a great fuel for performance use. We rally race and use it in our Evo Rally Car.
That said, we have to run larger injectors and a much higher flowing fuel pump in order to deliver the added amount of e85 needed to make the car run properly.
My advice to you, run regular fuel unless you're looking to burn up a motor. Alternatively, install an S-AFC and wideband like we did in our Jeepspeed to tune proper air/fuel ratios. Even then, if you can't take advantage of the e85 burning nice and cool for you by tuning timing, there isn't too much point in running e85 as your MPG's will decrease with proper tuning.
